Help Forum How To | General Corvetteforum Questions | Feedback
DBS question
Old Feb 6, 2010 | 06:56 PM
kaptainkirk's Avatar
kaptainkirk
8th Gear
Default DBS question
I have a 2005 coupe, about 41K mi. and have now experienced the "DBS"....What would it hurt to remove the battery when parking for winter/off season and leave on a battery charger or tender? What would the effect be with car electronics? I can live with resetting clock and radio stations, etc., but will my key FOB's still work when re-connecting? As far as getting the car open, if FOB works, I plan on leaving the hood ajar to re-install battery. Also, have heard the Optima is the way to go...as my factory Delco has already ran all the way dead.
Old Feb 6, 2010 | 07:20 PM
Vette_DD's Avatar
Vette_DD
You would have to reset the window indexing. That should be all.
Close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done.
This is called resetting of the window indexing or power window initialize and is in the owner's manual. See page 2-17 of the 2005 owner’s manual, page 2-18 of the 2006 owner’s manual, page 87 of the 2007 owner’s manual, page 2-18 of the 2008 owner’s manual, page 2-18 of the 2009 owner's manual, ,or page 3-18 of the 2010 owner's manual.
However, this help forum is for help with the forum itself. The type subject you're talking about should be posted in the C6 General forum.
http://forums.corvetteforum.com/c6-c...discussion-74/
Old Feb 7, 2010 | 01:37 PM
Zymurgy's Avatar
Zymurgy
Moderator
Why remove the battery? Put a tender on it and leave it installed. Also, has your car had the reflash done that addresses DBS?
To DBS question
