Help Forum How To | General Corvetteforum Questions | Feedback
Having trouble with CF locking up, etc?
Old Mar 7, 2010 | 07:51 AM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
I rooted around and found the defrag.
Old Mar 7, 2010 | 03:17 PM
2006c6keller's Avatar
2006c6keller
Default Look at the "Tools" tab again!
Originally Posted by 2006c6keller
Pull up MY Computer>right click>properties>disk cleanup>Tools (do errors & defrag). This might really help you.
PS: I just reloaded my Video Drivers and it solved my multiple lines and helped steady my cursor.
Originally Posted by Zymurgy
Pull up My Computer, then right click on your hard drive (C. The resulting dialog box should show you a pie chart with free and used space. Next to the pie chart is the Disk Cleanup button.
Originally Posted by CHASLS2
I do the disk clean up every week. I don't see where you can do a defrag.
(SEE MY COMMENT BELOW)
After Zymurgy above quote, click on the "TOOL" tab above and you will find the "error AND defrag", follow instruction and run both, "error" will run on restart with blue screen.
Also, if still not running correctly on the line repeating, I believe on another tab there, you can update the drivers, try to use disk that came with your Video card to do this.
Good luck!
PS: Later I deleted Norton Antivirus and loaded AVG antivirus and it solved the problem, in fact, it fould other errrors which Norton did not detect. Someone posted that Norton was a resource hog. He was right! I have only had only a few, maybe three problems since.
