Help Forum How To | General Corvetteforum Questions | Feedback
Bolding, Italics, etc
Old Feb 14, 2011 | 05:14 PM
dbdave's Avatar
dbdave
Default Bolding, Italics, etc
I used to be able to bold sections of quotes when replying to a thread but not any longer. In fact, none of the editing features above the reply box work. Any ideas as to why that may be? They used to work just fine.
Old Feb 14, 2011 | 05:21 PM
J T's Avatar
J T
IB Staff
If Javascript is not enabled in your browser, the menu above the message area for formatting will not work. If you're using Firefox and Noscript and blocking ibsrv.net that feature will also not work.
Old Feb 14, 2011 | 07:41 PM
dbdave's Avatar
dbdave
I'm using Safari 5.0.3 and Javascript is enabled.
Old Feb 14, 2011 | 08:17 PM
J T's Avatar
J T
IB Staff
I just tested with Safari 5.0.3 and the menu bar does work correctly, as shown in the following attachment.
If Javascript is enabled, then you may be blocking ibsrv.net or some security software setting is blocking the content.
Any other features not working? If you click on one of the smilies to the right of the message box, does the code insert? Do you see the drop-down menu for the Forums, Events, Store, Other, My Topics, Search, and Quick Links? When did this begin?
By the way, I'd try deleting your cache and making sure to restart Safari in case it's an internal glitch.
Old Feb 14, 2011 | 10:10 PM
dbdave's Avatar
dbdave
The drop down menu for the Forums, Events, etc was there, the smilies did not insert.
I emptied the cache and restarted Safari and now it appears everything works as it should.
May have been a recent Safari update that was installed or the recent changes to the reply page that caused the problem.
and thanks.
To Bolding, Italics, etc
