Help Forum How To | General Corvetteforum Questions | Feedback
Some smiles no longer work
Old Mar 27, 2011 | 12:55 AM
yellowvette837's Avatar
yellowvette837
St. Jude 15 Year Donor
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
Default Some smiles no longer work
For example
:d
:u
because the software changed the captial letters to lower case letters when I hit reply.
Old Mar 27, 2011 | 01:15 AM
J T's Avatar
J T
IB Staff
Originally Posted by yellowvette837
For example
:d
:u
I'm not seeing the issue. The code for smilies is CaSe sensitive, so using :d is not the same as if it were using: :D
Can you point to me where the software is changing the capital letters to lower case? It appears to be working fine for me:
Old Mar 27, 2011 | 02:15 AM
yellowvette837
I know the smiles are CaSe senstive, I have been here a long time.
If I type : (capital D) it will change it to : (lower case d) when I hit Reply. It even happen when I click on the smile. The code will start out as : (capital D) but when I hit reply it turns to : (lower case d) hence the smile no longer works.
Old Mar 27, 2011 | 02:25 AM
J T's Avatar
J T
IB Staff
Can you show me a direct example of where this happening? Because I was able to do it, as shown above, without any issue.
Does not appear to be changing to lower case for the above, otherwise, the smilies above would not work for me.
Old Mar 27, 2011 | 02:33 AM
J T's Avatar
J T
IB Staff
i know the smiles are case senstive, i have been here a long time.
If i type : (capital d) it will change it to : (lower case d) when i hit reply. It even happen when i click on the smile. The code will start out as : (capital d) but when i hit reply it turns to : (lower case d) hence the smile no longer works.
After doing some testing, I can replicate the issue. It will occur if you try to post the smilies by themselves. If no text is before or after them, they fail to work. This includes even if you quote a member, and just use those two smilies as a response. I found a deleted post by you with this example that helped lead to this discovery. If you add text before or after the smilies (more than just a quote), they will work.
Strange bug. I'll look into it.
Old Mar 27, 2011 | 07:49 AM
yellowvette837
Old Mar 27, 2011 | 08:10 AM
pewter99's Avatar
pewter99
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
yeah Jeremy this has been happening for awhile.. seems if you add some text or even a few .... it works but not always
Old Mar 27, 2011 | 09:05 AM
yellowvette837
Last night no matter how much text or ... I added the smiles would not work
Old Mar 27, 2011 | 09:15 AM
pewter99's Avatar
pewter99
the smilies must have went to bed
To Some smiles no longer work
