Moderators: I can no longer post replies to this site. I log in, am told "thanks for logging in", and then when I try to post am told that I'm not logged in. This circle jerk goes on until I finally close the site.
This not happen on any other site.
I quite often have info for the other members but can't post!
My first suggestion would be for you to delete your Corvette Forum cookies. Logging out is not enough to delete them. Depends on the browser you use as to how you do this, but I suggest you manually delete all (there will be several) Corvette Forum cookies. However, I don't suggest you delete cookies for ALL sites as you'll lose cookie-based preferences on other sites you visit.
Unfortunately there isn't anything we can do on this end to fix this. This is a classic corrupt cookie issue. It happens from time to time and can be an issue on any site. Due to the amount of cookies used, per site, the issue usually only impacts one site at at time. Hence why the issue is only occuring on this site at this time.
