Finally stepped up and got rid of my STOOPID phone, so I could post pics from my photobucket account, using my new Motorola Atrix (No computer) So...I figured out how to do one photo just fine, by copying the url of the pic, and paste it to my thread. When I try to do another pic, when I go to paste again, it only options me to copy. I am a techno caveman, so any info is appreciated!
I'm not familiar with the phone, but if you only get Copy and not Paste then that suggests the previous Copy did not work to allow a Paste. This would be an issue with the phone/OS itself and you may get better support from those sources.
It appears there is a few different ways to do this. 1) Tap twice to select the text. Then press and hold until a Menu appears to allow the selection of the Copy command. 2) Tap and hold on a URL/Link to allow the selection of the Copy command. 3) Tap on Settings/Menu button, tap on More, then look tap on Select text and select the text, which will then be copied.
Thanks! I'll play around with it some more. Much appreciated!
