I was wondering mostly what the stars mean under a persons name. And the criteria for junior and senior members. I'm assuming it's based on time in the forum but again newbie here. Also what do the colors of the stars mean? Plus how do you unlock the titles under the name. for instance when you donate to St. Judes does it update automaticly or do you have to PM someone in charge of it? anything else info wise would be helpful. I just like to know what I'm looking at when I see people replying to posts.
The color of the little stars doesn't mean anything. If you have a certain number of posts, you will have a certain number of stars and they will always be the color indicated in the thread that JT gave you a link to.
To address your particular question, the picture is called an avatar and you'd use the following steps:
To update your Avatar:
1) Go to UserCP: http://forums.corvetteforum.com/usercp.php
2) Under Settings & Options, click on Edit Avatar: http://forums.corvetteforum.com/prof...?do=editavatar
3) Click on Use Custom Avatar and use the Option 2 to upload the image from your computer
4) Click on the Browse button to open a new window to display the contents of your computer to locate the file you desire to upload as your Avatar
5) Locate the file from your computer that you desire to upload, select it, then click on the Open button
Make sure the image complies with the restrictions noted, otherwise it may fail to upload.
