I'm curious as to the link you was trying, which may be theme/skin related. The database shows you use the C4 theme as default, which is the same theme/skin I use myself. So not sure where you were getting a different link since we're using the very same theme/skin - unless you're overriding the theme/skin via cookies.
It would help to know further details to see if we need to fix something.
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Still trying to sort this out. I tried using IE9 and Chrome my default is Firefox.
All three failed the upload.
I dumped the cache as well as other temp folders.
Then clicked on your posted link and the problem has not resurfaced.
