I have been trying to change my signature and name in the edit user profile section per the description in the fac link. They are changed in the CP, but do not change when I make a post. Anybody help? Thanks.
Changes to the signature are made immediately to posts that you've attached your signature. If you're seeing something different, then it may be a browser cache issue.
If you're reporting the issue that your signature isn't displaying:
You must manually select "Show your signature" to show your signature each time you want it displayed:
Usernames can only be changed by an Administrator. You'll need to tell us what username you want to use instead. As CorvetteForum has over 315K members, you'll need to be specific with the username to ensure it's not already taken.
