Help Forum How To | General Corvetteforum Questions | Feedback
How do I post a picture from Flickr?
Old Aug 5, 2013 | 03:06 PM
Mpls Funk's Avatar
Mpls Funk
Default How do I post a picture from Flickr?
Hi all - I can't figure out how to post pictures from Flickr! Do I have to use photobucket? Any help would be appreciated.
Old Aug 5, 2013 | 03:52 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You should be able to copy the image link listed on Flickr and paste it into your Forum post.
Old Aug 5, 2013 | 04:28 PM
DC3's Avatar
DC3
I don't use Flickr but assume it works about the same as the others.
Go to Flickr. Right click on the photo you want and choose "Copy Image Location".
When you make a post on CF, just above the box you type in are a bunch of icons. Click on the square yellow one that looks like it has mountains on it. That is the "Insert Image" icon.
Then right click and paste the url you copied in the first step. Click "Ok".
DC
Old Aug 5, 2013 | 04:36 PM
Mpls Funk's Avatar
Mpls Funk
DC
Thank you!!!! Got it to work.
David Mc's Avatar
David Mc
While viewing your photo in Flickr there should be a little button on the bottom right to "share your photo".
A popup with size choices and html code will show up. Before I copy and paste the code here, I like to strip out all the extra garbage from the code so it's just what's between the {img][/img] tags.
Old Aug 5, 2013 | 04:38 PM
Mpls Funk's Avatar
Mpls Funk
Thanks David - I appreciate your help!
Old Aug 5, 2013 | 08:28 PM
jnealg's Avatar
jnealg
hmmmm, i have tried to use flickr before without success... lets try this...
Old Aug 5, 2013 | 08:29 PM
jnealg's Avatar
jnealg
kewl, thanks for the suggestion of removing the crap from the link.
Old Aug 6, 2013 | 11:53 AM
savewave's Avatar
savewave
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
NCM Lifetime Member
Interesting. Flickr at one time changed their rules to prohibit hot-linking to other sites and they set the codes up so you didn't get the results you expected if you tried to end-run the rules.
Glad to see they have come around.
To How do I post a picture from Flickr?
