Help Forum How To | General Corvetteforum Questions | Feedback
Side Menu
Old Oct 14, 2013 | 06:06 PM
Stan0324's Avatar
Stan0324
Default Side Menu
How come when you are in a C6 forum, the side menu shows C7 forums and in the C7 forum it shows C6 forums ?
Old Oct 14, 2013 | 06:37 PM
J T's Avatar
J T
IB Staff
You're using the default theme which is C7. Previously, prior to the C7, the C6 theme was the default theme. The default themes can also be set per forum.
If you want the C6 theme shown all the time:
1) Go to UserCP http://forums.corvetteforum.com/usercp.php
2) Go to Options http://forums.corvetteforum.com/prof...do=editoptions
3) Go to Forum Skin at the bottom and select C6 and then Save button
I'll look into correcting the issue with the inconsistency across the different forums but the above procedure would be good to do if all you want to see is the C6 theme.
