I'm having wrong screen pop up while trying to search and again wrong screen popping up when I try to access another members posts. A no results screen!
I'm OK here, at CF, but on LS1tech, which is also an IB operated website, the "my recent topics" feature has been unavailable to me for about 3-4 days now.
The issue you're having on LS1Tech is different from this previous issue and appears due to the recent installation of IE 11 on your computer. It appears there is a problem with the code and IE 11. We will investigate.
Thanks for the info....should I remove the IE 11, and go back to the previous version of IE that I had in place?
From what I can see, the issue you reported is specific to IE 11 and I can duplicate it with IE 11. So any other common browser or version should work fine. We will investigate the issue but I don't have a time frame of fix at this moment.
