Just a heads-up that when I click on the C5 link below my username it redirects me to the C6 section. The one time I was able to get into C5 General, all the community links in the left column were for C6. But, now I can't even get into the C5 section at all.
If clicking on one of the C1 - C7 links does not work in that the links to the left don't reflect the correct Corvette generation and the Corvette logo in the upper left corner also doesn't reflect the correct Corvette generation, first make sure that the "Default 2014" style/theme is selected. Go to the bottom of the page and in the lower left corner should be "Default 2014". If it's "Lightweight", change to "Default 2014" and then click on one of the C1 - C7 links in the Welcome box.
You may need to delete all CorvetteForum cookies. Please note that logging out does not clear all CorvetteForum cookies. Some browsers allow you to singly delete cookies while others require you delete them all - even for other websites. After clearing all CorvetteForum cookies, revisit the website, make sure to use the Remember Me option, log in, make sure the "Default 2014" theme/style is selected in the lower-left of the page, and then try the C1 - C7 links in the Welcome box.
