Can someone PLEASE help this idiot with step by step instructions on how to add photos to an existing ad. I have been trying for two days and when I think I have it, nothing. Thank you very much, Duke
You can upload them to CorvetteForum as Attachments:
1) Click on Manage Attachments below the area you type your message in as seen below:
2) Click on Browse button to locate the file on your computer as shown below:
3) Locate the file on your computer, select it, then click on Open as shown below:
4) If you have more files to upload, repeat step 2 and 3
5) When finished, click on the Upload button and verify the files are listed below the Current Attachments before clicking on the Close Window as shown below:
The attachments are added to your message. You simply continue to post your message as you normally would.
I need some more specifics as to exactly how far you get as I'm not following.
I have to get the photos by supplying the URL's , this is below the section where you browse your computer. The browsing part is not enabled to a basic forum member. When I do I get a list that appears as uploaded. That's as far as i get. Nothing shows up in the ad.
Without further information, I would suspect you're not supplying a valid file. Either the file is too large or not a normal extension.
