I keep hitting the HUGE submit button that spans across the bottom of the screen when typing a response. The submit button is very obtrusive when replying with a quoted post.
Why cant the submit button be out of the way? What can I do as a work around?
I missed the iOS part. I'm pretty sure that is by design, and is normal for any mobile theme or app, and you can't change that. You don't want small buttons on a mobile device.
Originally Posted by C5 Hardtop
if you tell me how to do it on the iPhone, yes.
Otherwise, here is a screenshot from an iPhone emulator.
This section is Help & Feedback and it is monitored. I suppose the submit button could be moved down, which then that's going to add white space and probably lead to complaints. I suppose it could be made smaller, but how smaller does it need to be to fix your issue without others reporting that it's too small to use on a small screen? It can't be customized per user.
There are two mobile device optimized ways to access CorvetteForum. One is the mobile skin/theme and the other is the official application available in the Google Play or Apple Store. The former is a style that is used across all Internet Brands' websites and they keep them all uniform for management and have some research time into the layout. They can't be customized per user. The latter, too, is used across all Internet Brands' websites and is not exactly customizable per site. The latter is going through a new beta version with beta testers.
What is the appropriate channel to provide site feedback?
