Help Forum How To | General Corvetteforum Questions | Feedback
Long running script
Old Apr 12, 2015 | 01:18 AM
tpfarm's Avatar
tpfarm
Default Long running script
Does anyone's computer just on the forums get really slow and get a message saying "corvette forum is not responding due to a long running script" if so what's the fix. sometimes I can't use the forum because it just hangs up for minutes at a time. thanks.
Old Apr 12, 2015 | 01:29 AM
The13Bats's Avatar
The13Bats
Have you tried different browsers?
You might try,
Open Internet Explorer
Click the 'Tools' menu, and then select 'Internet Options'
Click the 'Advanced' tab, select the 'Disable script debugging (Internet Explorer)' and 'Disable script debugging (Other)' check boxes
Clear the 'Display a notification about every script error' check box, and then click OK...
Might help....
Old Apr 12, 2015 | 09:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you get a "Stop Running Script?" message? If so, click Yes.
Old Apr 12, 2015 | 10:30 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
E. M. .............Same problem with my HP laptop......I click the "yes", but the "long-running script" message appears again.....after 3-4 tries the site finally is usable.....same problem when using Bat's suggestions/3-4 tries before problem is corrected.
Old Apr 12, 2015 | 10:45 AM
71scgc's Avatar
71scgc
It's gettin' a little old...
Carter
Old Apr 12, 2015 | 12:49 PM
tpfarm's Avatar
tpfarm
I have clicked yes many times to no avail.
Old Apr 12, 2015 | 12:50 PM
tpfarm's Avatar
tpfarm
I have HP also.
Old Apr 12, 2015 | 12:54 PM
ddawson's Avatar
ddawson
Ad Block and Disconnect removes all that crap running in the back ground.
On this page alone I show 25 ad blocks and 35 blocked requests. Facebook and stuff.
Old Apr 12, 2015 | 01:44 PM
kdlp's Avatar
kdlp
Yep, exact same thing happening here with both "Explorer" and "Firefox"... guess the popups are more important than the subscribers...
Some things I do not understand ... I'm told that's because "I'm too old." Funny though, because 50 years ago it was because "I'm too young."
kdlp
Old Apr 12, 2015 | 01:55 PM
tpfarm's Avatar
tpfarm
Thanks but where is Ad Block and Disconnect ?
Old Apr 12, 2015 | 03:21 PM
redvetracr's Avatar
redvetracr
voice your complaint on the help page...scroll down, way down
Old Apr 12, 2015 | 03:23 PM
dmaxx3500's Avatar
dmaxx3500
''ad block'' works great
Old Apr 12, 2015 | 04:28 PM
The13Bats's Avatar
The13Bats
I can't get mine to give the error some are getting,
I do not use ad blockers and I have no pop ups, and I am bloatware/malmare/etc free
My comp is built by me, running win7 pro with EI
While I do not believe this is the answer it can't hurt,
Run the free versions of avast, malwarebytes and even the wed based pc cillin house call, see if things are clean even if you have anti virus those things will not hurt anything.
Old Apr 13, 2015 | 12:07 AM
doorgunner's Avatar
doorgunner
I used my brother-in-law's laptop tonight....he lives 30 miles from my house.....his laptop had the same problem with different forums that I logged on to. He also has *** Communication as his provider---if that means anything?
Old Apr 19, 2015 | 12:07 AM
tpfarm's Avatar
tpfarm
Thanks for the tip installed AD Block and computer running much faster now.
To Long running script
