In order to assist we need more information, such as:
1) Do you notice any specific ad when the issue occurs, such as a video or flash ad? If so, you need to provide us with a screen capture and click through link. Even if the browser appears locked, the screen capture function should still work.
2) Provide what browser and version you're using.
3) State if you have any browser extensions.
Seems to be the ads that play uncontrolled at the bottom of a page, or off to the side. Both lap top, and desk top just do the beach ball , can't get it to do anything, including X out of CF let alone get a screen capture. Sometimes it Xes out all by itself. No problems on other sites.
I had a hard time posting this.
Unfortunately that doesn't help narrow down the problem as all ads aren't freezing the browser. We also need the requested information above.
I used IE 10 to browse around and despite the ads, and video ad, my browser did not lock up. I can say that I noticed some lag with IE that I don't with the Firefox browser I normally use.
I wouldn't be too surprised if it's an issue that's related to certain environments using the flash plugin, which can be used for video.
It's at it again. Freezes the site and all I get is a quick running list of "Waiting for xxxxxxx" across the grey scroll line. Same as last time when it was dismissed as being some kind of ad generator that was being corrected.
Not sure I understand why you say it was dismissed. I made it known that it was being looked into and that it was also found and corrected. It was corrected as members indicated at the time.
Again, in order to assist we need more information, such as:
I am not computer literate. All I can tell you is that for example Magnussen posted a 4 min video in PRC and 20 minutes later my computer was still doing the beach ball, within a minute of clicking on CF it sounds like a jet, and I literally have to hold the off button down to get out of here, and restart my computer. Yet I can go to you tube and watch the same video 10 times with no issues. The only way I was able to post this was to race to get it posted.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Still having slow operation here on this forum. Other sites run fine. Downloaded Adblock plus as recommended by a member. Might have improved things, but not perfect yet. This thread locked up on me a minute ago, and I had to re-sign in again.
Still working to try a couple other previous suggestions, but for now, perhaps an off immediate-topic question. Is there a way to disable the advertising videos at the end of what seems like every thread? I'm less annoyed at continually having to watch the KY lube advertisements as I'm concerned about the data/download quantity each time I visit another thread. I'm out in the boonies, and my only internet connection is a metered setup from one of the local cell companies. If possible, I'd like to not have to be continually billed for the data flow that these advertisements consume.
I can access anything on the site except c1-c2 general and I get a message that internet explorer is closing the program. No problem until yesterday and same problem today. Thanks
Delete your cache making sure it deletes CorvetteForum's data. If CorvetteForum is marked as a Favorite then you will need to deselect the Preserve Favorites Data option.
If that doesn't work, Microsoft's suggestion is to turn off IE and back on.
Didn't seem to change anything. I can access any part of the forum except the c1 c2 general discussion. Error message says internet explorer has stopped working. Thanks
Did you actually do what I recommended as well as what Microsoft's website recommended?
If Microsoft can't fix your issue, I doubt we can. So make sure to follow their instructions as I posted.
I get that on a semi-regular basis with Off Topic and PR&C. I'll give JT's suggestions a try, and hope for the best.
Yesterday and today I'm getting the "Internet Explorer is closing the program" as well.
Windows 7 and IE10.
Never seen this problem before.
Only happens in Off Topic. I seem to be able to access all other parts of the site. Haven't downloaded any thing new.
I'll try the suggestions above.
Update: Above suggestions didn't work for me. However, IE is back to normal today. All that I did was download the current version of Firefox, which then required the current version of Adobe Flash. I wouldn't think that those two downloads would have anything to do with my IE issue, but it's working again.
