Help Forum How To | General Corvetteforum Questions | Feedback
photos
Old Oct 5, 2015 | 06:54 PM
Bat66's Avatar
Bat66
Default photos
Anyone having problems attaching photos to this site, everytime I attach a pic its logs me out of the site.
Old Oct 5, 2015 | 07:08 PM
ChevyDave's Avatar
ChevyDave
tested in TEST forum and worked fine...
https://www.corvetteforum.com/forums...ding-pics.html
however i did see someone there having trouble...
post #2..
https://www.corvetteforum.com/forums...mage-link.html
i'd say , pop over there to testing forum location, try some more , shoot Moderator(s) a note if still trouble
Old Oct 5, 2015 | 07:23 PM
rado63's Avatar
rado63
I haven't had any trouble inserting a photo into a reply. I might suggest you resize the image before you attempt to add it to your post. A possible reason may be that if the image format or file size is too large, it might have trouble uploading. Just a thought.
Old Oct 5, 2015 | 07:49 PM
Vette_DD's Avatar
Vette_DD
Go to the HELP forum and explain your problem. Here's a link to that forum:
https://www.corvetteforum.com/forums/help-forum-31/
That's what that forum is for. JT will help you.
Old Oct 5, 2015 | 08:48 PM
J T's Avatar
J T
IB Staff
The only known issue with attaching images is images not properly being inserted if using IE browser and the Enhanced Editor. Until the issue is resolved, we suggest going to UserCP, Edit Options and change the Message Interface (near bottom) to Standard.
However, the issue does not log members out. If you are indeed getting logged out, you have a separate issue - likely a cookie issue with your browser. Yes, it probably only happens only on CorvetteForum because almost every site uses different cookies and one corrupt cookie will generally only cause an issue on one site only. The fix to that issue is to delete all your CorvetteForum cookies.
To photos
