Appears to be working correctly for me. State the browser you're using, any extensions, and if using a mobile or desktop. The function relies on your browser to work correctly.
Also, to be clear, the multi-quote feature only works per thread. You can't use it to quote posts from different threads. In that case, the posts will not appear. You can only multi-quote posts within the original thread.
Originally Posted by Corvette Kid
Regular quote button (for one post) still works fine but when trying to use multi-quote, those posts do not show up on reply page.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Well you show to be using the Standard Editor, which I used in my previous Multi-quote reply with screen capture as well as this one and it works fine.
I'd suspect it's something with your browser given the browser does some of the work and I duplicated your environment (browser and editor) without experiencing your issue.
