stop email notifications
What to do?
1) You can manually change the Thread Subscription Notification Type for each thread in the Advanced section when replying if you want to customize the notification per thread. Note that once you've already subscribed to the thread, you must then use #2 to make a change.
2) Go to UserCP, View all Subscribed Threads, and manually change the options for that thread.
3) To change default behavior - Go to UserCP, Edit Options and Find Default Thread Subscription Mode and change it. That will apply moving forward. However, this will not change previous thread subscriptions. Previous thread subscriptions must be edited using #2.
In other words, #3 method is the default but it does not get overridden if you use #1 or #2
This behavior is 100% the same as all other websites that runs forums based on the vBulletin software. Which is a couple.
Hopefully it works. I guess my first thread was just too successful.
