Help Forum How To | General Corvetteforum Questions | Feedback
won't run
Old Jun 3, 2019 | 12:25 PM
wrobson's Avatar
wrobson
6th Gear
Default won't run
I changed the distributor shaft, plugs, cap and rotor. Set the timing and points statically. It starts right up and runs, then it spits through the carburetor
and dies. what gives?
Old Jun 3, 2019 | 01:59 PM
J T's Avatar
J T
IB Staff
This Help section is for Help with the CorvetteForum website (account issues, etc.,) and is not the place to post technical questions about Corvettes. Instead, please find the correct section, based on the generation of the Corvette.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. C3? Since you didn't provide any information, you will need to determine what generation your Corvette is an use that appropriate section.
Thank-you
