Hi Jack - Do you know how I can change my Forum Name? When I originally registered, I had a 2016 Stingray and now I have a 2019 ZR1. Thanks
Only Administrators can change a user's name.
You will need to provide atleast 3 usernames you want to use. Since CorvetteForum has over 476K members and has been online for nearly 20 years, most common usernames are already taken so you will need to provide atleast 3 usernames in case any of them are already in use.
PM your answer to the above.
Hi JT - I couldn't figure out how to PM you, so hopefully, this will work. If possible, I would like to change my user name to: "George ZR1" or "GW ZR1".
