I just recently upgraded the software on my IPad Pro and no longer can log into Corvette Forum using my username and password, but it still works for my iPhone and desktop. I had a similar problem last yr and someone had sent me a link or suggested how to log in using the Google search engine on my IPad. I had the link bookmark but it’s still not allowing me to log in. Keep getting the error username or password is incorrect. If someone can send me a link or is there an App I can add to login I’ll appreciate it.
Thanks,
Ron
If one receives the incorrect username and/or password error, then one is entering in the wrong username and/or password. The system does not mess up by incorrectly looking up the wrong data.
The error does not state if it's the wrong username or a wrong password. Note that passwords are CaSe sensitive.
There is no special log in link to make this work any different. The only possibility is you're not visiting the correct website. Over the years, a few members have mistakenly tried to log into a sister website https://www.corvetteforums.com (note the S at the end) and of course that may not work if they don't have an account on that website with the same username and password as the two websites are not connected.
I was able to login using my IPad. I’m not sure what the issue was that was allowing mr to login manually, but using a saved password word using the touch function.
For clarification, you was not manually entering in your username and password to log in when you received the error? Instead, when you was prompted to enter your username and password your browser had a dialog to automatically populate the information?
If that's the case, you was using the browser's built-in account feature. So either it has wrong/corrupt information or you changed your username and/or password at some point after you saved/stored your username and password in the browser. This is independent of CorvetteForum. Meaning, if you change your username and/or password and you're using the browser's built-in account feature, the two don't resync automatically and your browser won't have the updated information. This would apply to just about any other website using account-based access.
