Help Forum How To | General Corvetteforum Questions | Feedback
C5 LED bulb replacement problems
Old Oct 8, 2019 | 07:19 PM
km60sb@yahoo.com's Avatar
km60sb@yahoo.com
Default C5 LED bulb replacement problems
Hi there.
In August of this year I replaced my 02 C5s instrument cluster, HUD, and DIC bulbs with LEDs bulbs. For the past 2 weeks I’ve been getting code PCM 0650 & check engine light staying on after I clear the PCM 0650. I disconnected the battery overnight and the check engine light went off and after driving for 20 minutes it turned on. Reading older posts on CF the code is a malfunctioning Check Engine light. Has anyone solved this problem without changing LED bulbs back to the OEM incandescent
bulbs in the instrument cluster??
Old Oct 8, 2019 | 10:38 PM
J T's Avatar
J T
IB Staff
Originally Posted by km60sb@yahoo.com
Hi there.
This Help section is for Help with the CorvetteForum website (account issues, etc.,) and is not the place to post technical questions about Corvettes. Instead, please find the correct section, based on the generation of the Corvette.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. C5? That's covered under the C5 Corvettes, 1997 - 2004 section:
https://www.corvetteforum.com/forums...s-1997-2004-2/
Got a technical question about the C5? Use the C5 Technical section:
https://www.corvetteforum.com/forums/c5-tech-1/
General question? There's a C5 General Section:
https://www.corvetteforum.com/forums/c5-general-103/
Thank-you
