C2 Driver's Side Headlight Motor Assembly
Next came the driver's side with the same results. However, as happened with the passenger side motor, when I removed the electrical component from the housing and the brass bearing came with it, I could not get it off the shaft. Fearing that I might damage it, I took it to a machine shop who charged me $20 to remove it. The gentleman there told me that the reason it was difficult to remove was because of the gear like notches at the base of the shaft. Those notches are not on the passenger side component. What is their purpose? So, I cleaned and lubricated everything and reassembled the motor being careful not to force the brass bearing over the notches on the shaft. But!!! In doing so, the electrical component binds against the magnets and does not turn freely. It appears that the brass bearing must be pressed onto the shaft in order for the electrical component to seat properly in the housing. Won't that inhibit the rotation of the shaft? Any advice will be greatly appreciated. Thanks.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see your generation of Corvette listed.
C1 or C2 (1953 - 1967)?:
https://www.corvetteforum.com/forums...2-corvettes-4/
