scan tools not working...C.E.L is on
C.E.L. came on dash. Actron CP9185 screen said "Operating error, check connections & retry". I could not get it to read anything. The C.E.L. stayed on, thus fuse must be good. At Autozone, their code reader could not connect & their tech's personal WiFi reader also failed. Their is no corrosion on the connections. Actron told me to use Global setting on the CP9185, to no avail. The Actron CP9185 works fine on my 2000 Maxima. The C6 runs fine...I just want to shut the C.E.L. off
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. C6 Corvette, 2005 - 2013 section:
https://www.corvetteforum.com/forums...-2005-2013-14/
Got a technical question about the C6 Corvette? Use the C6 Tech/Performance section:
https://www.corvetteforum.com/forums...rformance-101/
Thank-you
