I need some help reinstalling the reverse shifter ring on my C4 six-speed. I pulled off the shift **** and reverse ring to install a new shifter boot. When I loosened the reverse ring set screw, the center reverse pin seemed to drop just a bit. I could then get the ring off. Now I am trying to reinstall the ring. Seems like to I need to pull the reverse pin up some small amount to be able to tighten the set screw. The reverse pin does appear to have an indent and inch and a half down the pin. Is it just trial and error trying to pull the center reverse pin up enough that the set screw will go in? Tried now for about and hour. Pulling the pin up with needle nose pliers and turning the set screw. I did pull the ring off, tightened the screw all the way, put the ring on, then slowly backed out the set screw until the ring went down. Still cant get the set screw to "bite" the reverse pin. Reverse ring is not stripped or split. Any ideas? What am I missing? This seemed like such a simple task.
This Help section is for Help with the CorvetteForum website (account issues, etc.,) and is not the place to post technical questions about Corvettes or other questions not related to the website. Instead, please find the correct section, based on the generation of the Corvette.
We encourage new members to take some time to browse around the site and read the Announcements and Stickies as they contain important and frequently asked information.
