BCM body control module 16155502
He has asked for advice on the internet and someone has told him its either the BCM or a module that plugs into the back of the dash. A few years ago I had a dash from a friend from a 91 but it acted the same with led segments not working. I not sure that dash module is the answer nor is the mechanic.
We checked the BCM earth wire and it was showing a fault so he ran a new wire but didnt help the LED dash segments.
In short ,shall I upgrade the BCM with a new unit, recon or used? If so what should I pay and is ebay the best source?
With the dash module I am not sure its name and part number so would apprecate that.
Being based in Australia, the spare parts will have to come from the US. A few names would be apprecated.
Regards
Neville
Regards
Neville
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. C4 Corvettes, 1984 - 1996:
https://www.corvetteforum.com/forums...-1984-1996-19/
Got a technical question about the C4 Corvette? Use the C4 Tech section:
We encourage new members to take some time to browse around the site and read the Announcements and Stickies as they contain important and frequently asked information.
Thank-you
