Help Forum How To | General Corvetteforum Questions | Feedback
Camera transmission switch
Old Mar 17, 2021 | 01:12 PM
Pmazurko's Avatar
Pmazurko
Default Camera transmission switch
If you disconnect for any reason and now want to connect back up, note that the Two Prongs inside the tranny end are not in the center. They are a little to one end and you must insert the Female end at the end of your wire in properly or you will bend them. This means a new switch or trying to straighten them by taking it off the tranny.This is what I did working without a light. The tyranny end has a Grove that matches up with the Grove on the wire end. $47.00 mistake!
Old Mar 17, 2021 | 01:15 PM
J T's Avatar
J T
IB Staff
This Help section is for Help with the CorvetteForum website (account issues, etc.,) and is not the place to post technical questions about Corvettes. Instead, please find the correct section, based on the generation of the Corvette.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. C7 Corvette, 2014 - 2019 section:
https://www.corvetteforum.com/forums...2014-2019-141/
Got a technical question about the C7 Corvette? Use the C7 Tech/Performance section:
https://www.corvetteforum.com/forums...rformance-169/
We encourage new members to take some time to browse around the site and read the Announcements and Stickies as they contain important and frequently asked information.
Thank-you
