Somehow I have lost the ability to select text/image and right click and paste into a post. What am I doing wrong? I am using Edge
Copy/paste is a function of your browser and OS. There is no setting on CorvetteForum and CorvetteForum's software doesn't known if you copy paste or not as it's not involved. You might try rebooting.
Copy/paste of an image is not supported and hasn't been. Copy/paste a URL of an image, has been, but not the image itself. It might appear correctly to you, but it will not to those reading.
I need to back-up for a second as I think I see what your issue is. You must be using the Right-Click within the Message area and not seeing the Copy or Paste command in the browser's menu. I can confirm that issue as it appears the browser doesn't recognize that the area is a message area where Copy/Paste menu options are valid. I'll discuss this with the team.
Note that copy/paste does work. CTRL+V in the message area and you'll see the contents pasted as that's the keyboard shortcut key.
