Help Forum How To | General Corvetteforum Questions | Feedback
1996 C4 tach issue
Old Aug 26, 2021 | 02:58 PM
bfigueroa's Avatar
bfigueroa
Default 1996 C4 tach issue
I have a 1996 C4 Vette and have read several posts within this forum and additional internet searches re: problems with the C4 Corvette tach. Everything from tack quit working, to incorrect readings, etc. The replies suggest many different possibilities: an electrical short, a bad TBS or tach filter or cluster circuit board. I was hoping someone may have experienced my specific problem and be able to identify a more specific area I can concentrate / focus my attention. Problem: Biggest issue is my problem is intermittent. Tach works most of the time and functions with no issues, but every now and then the tach “pegs” when turn on the ignition. After starting the tach shows an idle speed of approximately 2200 RPM when the idle speed, based on sound, is actually normal. If the car sits for a couple of days and start the car all is normal until the next time the tach decides to act up. Based on the above there may be no more specific suggestions available. Just hoping someone has experienced my specific problem and may have a suggestion other than it could be a multitude of issues. Any suggestions will be appreciated. Thanks Bob
Old Aug 26, 2021 | 03:42 PM
J T's Avatar
J T
IB Staff
This Help section is for Help with the CorvetteForum website (account issues, etc.,) and is not the place to post technical questions about Corvettes or other questions not related to the website. Instead, please find the correct section, based on the generation of the Corvette.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. C4 Corvettes, 1984 - 1996:
https://www.corvetteforum.com/forums...-1984-1996-19/
Got a technical question about the C4 Corvette? Use the C4 Tech section:
We encourage new members to take some time to browse around the site and read the Announcements and Stickies as they contain important and frequently asked information.
Thank-you
