Help Forum How To | General Corvetteforum Questions | Feedback
Problem with this forum
Old Oct 30, 2021 | 11:38 AM
Awkwardcrane's Avatar
Awkwardcrane
Default Problem with this forum
This happens repeatedly on here. The website stops, I get a message that there was a problem, it comes back, ten seconds later it does it again, and then says because of repeated problem it won’t open website.
I have tried with and without my add blocker and doesn’t make a difference.
If it makes a difference I use an iPad.
Old Oct 30, 2021 | 11:40 AM
IB4TL's Avatar
IB4TL
I don't have that issue with my laptop or phone.
May be a browser or cookie issue you're having 🤷‍♂️
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Ib4tl
Old Oct 30, 2021 | 11:41 AM
IB4TL's Avatar
IB4TL
Originally Posted by 04 commemorative
Ib4tl
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Site is working as advertised. No problem here.
Elmer
Old Oct 30, 2021 | 11:44 AM
scottycards's Avatar
scottycards
St. Jude Donor '08 thru '13
Desktop running Mac OS Catalina 10.15.7 using Safari 15.0 browser.
Page loads, then reloads on its own, does it again, then goes grey, with a button prompt to "Reload Page".
There is definitely a glitch.
I typically have about 10 browser tabs open at a time, and this is the only site that does it.
Old Oct 30, 2021 | 11:50 AM
Awkwardcrane
It’s the only this site I have a problem with also. And it’s on all of the site. I go to look at the picture thread or meme thread and can only look at one or two before it stops.
Old Oct 30, 2021 | 11:57 AM
scottycards
Just did it again.
I click the thread, it loads, then immediately loads again, then I get this:
Old Oct 30, 2021 | 12:11 PM
IB4TL's Avatar
IB4TL
Is everyone that's having issues using Apple products?
Old Oct 30, 2021 | 12:15 PM
Vette_DD's Avatar
Vette_DD
No such problems with my access to the website. I come on here 5 or 6 times a day, for about 20 to 30 minutes at a time, from my desktop computer.
It's got to be on your end.
Old Oct 30, 2021 | 12:53 PM
dvarapala's Avatar
dvarapala
Making CFOT Great Again
^ this
Old Oct 30, 2021 | 04:44 PM
J T's Avatar
J T
IB Staff
Try to disable javascript and see if the problem stops.
That said, you can go to Apple's own support to see this is not a CorvetteForum-only issue and may be related to a mismatch build/install of Safari. The issue doesn't occur for every website but that doesn't necessarily mean the website is the problem.
Old Oct 30, 2021 | 05:58 PM
Awkwardcrane
J T
I disabled JavaScript and it appears to be working fine now.
Old Oct 30, 2021 | 06:07 PM
J T's Avatar
J T
IB Staff
J T
Javascript is used throughout the site to increase the functionality and is the case for a lot of other websites. So certain features will not work with it disabled. This result just helps to pinpoint the issue is likely with the browser installation. You may need to re-install the browser but the problem may not be solved if the framework mismatch is still present between the OS and Safari, as this appears to be a known issue with Apple.
To Problem with this forum
