Help Forum How To | General Corvetteforum Questions | Feedback
not seeing photos in posts
Old Jun 30, 2022 | 04:38 PM
ChristyB's Avatar
ChristyB
Default not seeing photos in posts
Just lately I am not seeing photos folks post in threads. I am using an iPad. I did check my user panel and everything seems OK there. Thank you for any help. ~ Christy
Old Jun 30, 2022 | 05:46 PM
J T's Avatar
J T
IB Staff
There is no known issue so it's going to be one of the following:
1. Browser is blocking images. You will need to consult with your browser's help to check and adjust.
2. You have 3rd party extensions that may be blocking the content. You will need to disable the extension or adjust settings.
3. You are viewing posts with hot-linked images (images hosted outside of CorvetteForum). In that case, we have no control over content outside of CorvetteForum.
4. It may be a browser-related issue, in which case provide the browser information so that we can review.
Old Jun 30, 2022 | 11:04 PM
brassplyer's Avatar
brassplyer
I'm seeing the same thing here - just noticed it within the last 24 - 48 hours or so. Tried on Firefox, Chrome, Brave (my default), Edge - I've changed nothing on any of them, I was seeing photos fine previously.
I just commented on it in one of the other sub areas because I can't see photos and thought to look in here.
I tried it on my Android phone - same issue, doesn't matter if I use mobile data or WiFi. I can see videos but not pics that are hosted here. I looked at the For Sale area in the C3, I can see the image on this one thread but apparently the image is hosted by BAT, it's not hosted on CF. I'm also not seeing the image on the "Sponsored by" in the upper right by my avatar. It seems to be related to images hosted on CF.
https://www.corvetteforum.com/forums...ac-on-bat.html
Old Jul 1, 2022 | 12:12 AM
J T's Avatar
J T
IB Staff
It appears both of you (ChristyB and brassplyer) are not only using a VPN, but appears to be the same VPN provider. This is not an issue with CorvetteForum, nor the browser or account, but is your VPN provider.
We can't provide support for VPN services, so you'll need to use a different VPN or disable it.
Old Jul 1, 2022 | 12:52 AM
brassplyer's Avatar
brassplyer
Interesting - it does seem to be related to the VPN but only with images hosted on this site - no problem elsewhere - Facebook, ebay, BAT, etc. Was something recently changed with CF's image hosting? As I say it was fine until a couple of days ago.
I can see everyone's avatar images.
Old Jul 1, 2022 | 02:37 PM
ChristyB's Avatar
ChristyB
Thank you JT, I appreciate your reply. Yes, just recently I installed a VPN on my tablet. I guessed that might be the problem. The strange thing is, I can't seem to turn it off. brassplyr, can you turn yours off? BTW, I am a harp player.
Old Jul 1, 2022 | 03:35 PM
brassplyer's Avatar
brassplyer
I have ExpressVPN - the most prominent feature on the interface is a virtual On/Off button - mine works fine.
I have a query in to tech support - I'll let you know what they say. I'm not ready to exonerate CF yet for reasons previously mentioned but we'll see.
Old Jul 1, 2022 | 04:25 PM
J T's Avatar
J T
IB Staff
We are not aware of our NOC blocking images via your VPN, yet allowing everything else, and it's not typical. We do block some VPNs but that occurs at Cloudflare due to abuse. We can't change that.
Regardless of where the issue is, we can't provide support for VPNs so you will need to disable VPN or use a different VPN if this continues to be an issue.
Just for your reference, your VPN issue is with one of our asset servers: ibsrv.net. That's where some of our remote content comes from - such as attachments.
Old Jul 2, 2022 | 07:32 AM
ChristyB's Avatar
ChristyB
JT, for some reason I had loaded an older version of my VPN. When I updated it and learned how to turn it off, images showed up in this forum. Thank you for taking the time to help.
Once, long, long ago, I was a mod in a very large v-bulletin forum. I know how much time and effort it takes to provide help.
Thanks again ~ Christy
Old Jul 6, 2022 | 02:00 AM
brassplyer's Avatar
brassplyer
A new wrinkle - I just discovered I can't get onto bikeforums.net at all - I get a message saying the IP address is blocked. It's my understanding that corvetteforum and bikeforums are owned by the same people - they obviously use the same site environment.
Old Jul 6, 2022 | 04:50 AM
J T's Avatar
J T
IB Staff
With or without the VPN? What is the exact error? Is the error coming from Cloudflare or directly from the site itself? There is a difference.
Both sites are under Internet Brands, however, there is some different infrastructure so to speak.
Old Jul 6, 2022 | 05:16 AM
brassplyer's Avatar
brassplyer
With the VPN on. The last time I logged on probably within the last couple of weeks and for a long time before that this wasn't a problem, just as I never had the issue with images on CF while using the same VPN until recently.
This is what comes up. I also just made the discovery that CF won't accept an upload of an image with the VPN on - gets to 90% and stops, also not an issue previously. I see there's a mention of Cloudflare, I've seen the name before, I'm not versed as to what that is - I have a vague notion that it's related to security.
Old Jul 17, 2022 | 11:04 PM
Kiddbats's Avatar
Kiddbats
I have the same issue with express vpn, any solution? Other than just shutting it off?
Old Jul 18, 2022 | 03:30 AM
brassplyer's Avatar
brassplyer
Doesn't look like it - something related to images on here changed and now chokes on the VPN where it didn't previously. Doesn't sound like they have any interest in doing anything about it.
I never did get a response to my inquiry to Express VPN.
To not seeing photos in posts
