Help Forum How To | General Corvetteforum Questions | Feedback
94 C4 Overheating
Old Jul 16, 2022 | 09:11 PM
Matoh23's Avatar
Matoh23
3rd Gear
Default 94 C4 Overheating
I am a new corvette owner and previous owner of an NHRA 2002 Trans Am, so this would be my first LT1.
I recently purchased a 94' LT1 and knew it was going to be a bit of work, but after day 1 I'm either missing the "reason for everything" issue, or multiple issues all together. I have the common issues such as my fuel gauge reading incorrectly, though I found it odd that my car smells like it's running extremely rich. It started to smell like everything was burning (No leaks). I know the water pump was replaced as well as optispark. Now onto the issues.
On a cold start, the vehicle will idle as if there is a vacuum leak, revving up to about 1200 and dropping until the vehicle shakes and near-stalls, once I rev the vehicle, there's a bit of a delay, the car "hiccups", revs up, and all is back to normal idling. After driving around for thirty minutes, I noticed my coolant temp was sitting at ~250, at times just barely reaching the line at the 260 mark. This would fluctuate between 240-250. I have no lights on the dash, no codes as of right now.
When getting the vehicle home, it was insanely hot under the hood, I know these vehicles run hot, but this was so hot that after three hours of sitting in my garage, the motor is still too hot to touch. The fans DO kick on while driving, keeping it at a consistent 240-250 while driving it home. The only other thing I noticed is it would appear my power steering pulley is pretty wobbly, feels pretty tight on there but there's a noticeable wobble when the motor is running, maybe the shaft? I've seen someone post in this forum that pulley wobble can be normal?
Coolant levels are fine, though it's definitely boiling in there when the vehicle shuts off for a good thirty minutes or so.
Lastly, my oil pressure will sit comfortably in the mid-section while driving, around that 40-50 mark, and at idle, will sit at ~5-10.
Aside from checking the thermostat and radiator and filters, am I missing one of these "c4 problems" issues? Knowing my fuel gauge is incorrect, is it common for the rest of these gauges to be responding to the drive and just sitting at incorrect numbers, and these lt1's to get this hot and take this long to cool down? Thank you so much for any input.
Old Jul 16, 2022 | 09:17 PM
J T's Avatar
J T
IB Staff
This Help section is for Help with the CorvetteForum website (account issues, etc.,) and is not the place to post technical questions about Corvettes or other questions not related to the website. Instead, please find the correct section, based on the generation of the Corvette.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. C4 Corvettes, 1984 - 1996:
https://www.corvetteforum.com/forums...-1984-1996-19/
Got a technical question about the C4 Corvette? Use the C4 Tech section:
We encourage new members to take some time to browse around the site and read the Announcements and Stickies as they contain important and frequently asked information.
Thank-you
Old Aug 19, 2022 | 09:51 PM
Fast blue's Avatar
Fast blue
1st Gear
I had the same problems and I changed all kinds of stuff , running out of options I changed the throttle pressure valve on the fuel rail and it fixed all my problems, no gas smell no running roughly no high temp all is great, after spending tons of money the part was 45.00
Old Aug 19, 2022 | 10:06 PM
Vette_DD's Avatar
Vette_DD
Did you miss this in the post above yours:
Old Aug 19, 2022 | 11:16 PM
Purple92's Avatar
Purple92
Mods - Can you move this to the C4 Tech Forum.
Matoh23 - A normal LT1/LT4 powered C4 will run around 195 degrees on the highway, and will run up to about 230 in traffic. (These numbers are based on the digital temp display - not the gauge). Before going any further - I'd suggest verifying that the numbers are correct with an IR temp "gun" checking the upper rad hose / thermostat housing. Assuming that the temps you are seeing check out - I'll give my standard advice.
Step #1 - Do a full cooling system drain and refill - including pulling the two knock sensors (threaded into the block drain holes). You may be quite surprised with what comes out of those block drains... Refill with a 50/50 mix of distilled water and full strength anti-freeze.
Step #2 - A lot of "crap" can accumulate between the radiator and the condenser. Unfortunately the only way to really deal with this is to remove the radiator and clean out the mess. It's not a fun job and you'll hate the engineer who designed the six little screws that hold the nose of the air duct in place that have to come out to remove the rad. Again - you may be amazed by how much crud can collect in there. I suppose it's possible that you have a thermostat that isn't opening fully - but that is somewhat unlikley (but it's far far far easier to change a thermostat than is is to pull the radiator out).
Old Aug 20, 2022 | 12:07 AM
J T's Avatar
J T
IB Staff
The member already has an active thread in the C4 section:
https://www.corvetteforum.com/forums...erheating.html
Please continue the discussion in the C4 section. We provide instructions to members as to where, and how, to post to help members learn how to use CorvetteForum - and similar sites like CorvetteForum.
Thank-you.
To 94 C4 Overheating
