Help Forum How To | General Corvetteforum Questions | Feedback
Low Voltage / check gauges problem
Old Sep 7, 2022 | 06:23 PM
98cuzadam's Avatar
98cuzadam
1st Gear
Default Low Voltage / check gauges problem
I Have a 98 C5 automatic and once i turn the key it starts fine gauges swing then cluster goes dead then says low Voltage and the check gauges light comes on
in about a minute or few the gauges are fine and the Voltage starts to climb up to were it needs to be. The car runs fine while this is going on. so after a few minutes the car and gauges work like nothing happed .
new battery
checked cables
checked all grounds
pulled ignition and cleaned wire connecters on ignition
Old Sep 7, 2022 | 06:33 PM
J T's Avatar
J T
IB Staff
new battery
checked cables
checked all grounds
This Help section is for Help with the CorvetteForum website (account issues, etc.,) and is not the place to post technical questions about Corvettes. Instead, please find the correct section, based on the generation of the Corvette.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. C5? That's covered under the C5 Corvettes, 1997 - 2004 section:
https://www.corvetteforum.com/forums...s-1997-2004-2/
Got a technical question about the C5? Use the C5 Technical section:
https://www.corvetteforum.com/forums/c5-tech-1/
General question? There's a C5 General Section:
https://www.corvetteforum.com/forums/c5-general-103/
We encourage new members to take some time to browse around the site and read the Announcements and Stickies as they contain important and frequently asked information.
Thank-you
