shift clutch problem C 4 4+3 '88
could not shift gears.....pulled over to side of road and waited a few minutes and managed
to get rolling again but still had a hard time getting in gear but did make it home. Today is second day
since the problem and I drove around the parking lot of my condo and had no problem getting in
reverse and shifting from 1st to 2nd gear....am afraid to get on the road to do a test because I might
get stranded......clutch has maybe 300 miles on it and trans has always worked well ....could water
have caused this problem ? I guess I will have to suck it up and hit the road to really find out. Anyone
have any thoughts ? Thanks in advance
You should post about your problem here:
https://www.corvetteforum.com/forums...discussion-34/
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. C4 Corvettes, 1984 - 1996:
https://www.corvetteforum.com/forums...-1984-1996-19/
Got a technical question about the C4 Corvette? Use the C4 Tech section:
We encourage new members to take some time to browse around the site and read the Announcements and Stickies as they contain important and frequently asked information.
Thank-you
