C3 Corvette Wheels
I was wondering if anyone knew whether Torq thrust wheels would work with Wilwood front spindles (4 piston calipers) and what sizes? The Wilwood replacement 4 piston calipers were larger on the rear so, the stock wheels don't clear. Also, I have offset trailing arms on the back so, I'd like to run a wider tire. Any thoughts on this?
PS: This car is a frame off resto mod.
Thanks and God bless!
Instead, please find the correct section, based on the generation of the Corvette.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see your generation of Corvette listed. C3 (1968 - 1982):
C3 Technical: https://www.corvetteforum.com/forums...performance-3/
Additionally, you might also look into the Wheels and Tires section for all Corvettes:
https://www.corvetteforum.com/forums...s-and-tires-6/
We encourage new members to take some time to browse around the site and read the Announcements and Stickies as they contain important and frequently asked information.
Thank-you
