35th Anniversary Edition
Way back, AT ABOUT 8000 MILES, after long periods of being stored, it developed "Service Engine" SOMETIMES....I mean it is intermittent....If it starts and the message does not come on...then it will 'not come on' as I drive....
If I start it, and the message comes on.....then it stays on ...
Again, intermittent depending if the light comes on or not....WHEN I START THE MOTOR...
I noticed often, that if the engine starts without hesitation/ real quick...i.e. right after the key is turned on....then most of the time the light does not come on...
But if I have the starter going longed before it fires....the message usually always ...comes on!
I feel it is likely with a sensor, since the car is not used/ stored ...for many months in a year...
Someone told me to get a ...CODE READER ...and plug it in to find if it is a sensor ...
Also I try to always fuel it ..........with "no ethanol" fuel...!!
Can you advise me....if you have experienced this..
Often, after running the car for a long time...if I shut it off and re-start it...the light will stay OFF!
DENIS
https://www.corvetteforum.com/forums...erformance-48/
DENIS
Instead, please find the correct section, based on the generation of the Corvette.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. C4 Corvettes, 1984 - 1996:
https://www.corvetteforum.com/forums...-1984-1996-19/
Got a technical question about the C4 Corvette? Use the C4 Tech section:
We encourage new members to take some time to browse around the site and read the Announcements and Stickies as they contain important and frequently asked information.
Thank-you
