Help Forum How To | General Corvetteforum Questions | Feedback
C7 Stingray hard top alignment
Old May 1, 2024 | 10:55 AM
DanHorne's Avatar
DanHorne
Cruising
Default C7 Stingray hard top alignment
I'm a newbie to the forum. Hoping someone can help with an alignment issue with my hardtop. The top when on produces this annoying wind noise at speed. I put silicone on all the gaskets around where the top latches onto the body but it doesn't help. You can see the obvious mis-alingment of the top when installed. I see no adjustment available except for the latching hook at the rear of the top. Is this a dealer job or is there a method I can use to correct the alignment? Thanks, Dan
Old May 1, 2024 | 11:12 AM
ZR-71's Avatar
ZR-71
St. Jude Donor '15
This Forum is for help with questions on how to use the Forum
You need to ask your questions in the C7 Section
https://www.corvetteforum.com/forums...iscussion-142/
