Loosing break fluid
Have identified brake fluid spill (large spot) approximately 6 to 8 inches inside the left rear tire toward the center of the automobile...left to right.
There is a flexible brake fluid line in this area between the ridged left brake fluid line and the wheel mounted brake assembly with connecting points at the brake line and the wheel brake assembly.
Any identified historical problems with catastrophic break fluid loss in this area of the automobile for this model...C5 corvette?
Failed connection seals...ruptured line? All fluid lines are stainless steel...correct?
Any impute will be helpful.
Instead, please find the correct section, based on the generation of the Corvette.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. C5? That's covered under the C5 Corvettes, 1997 - 2004 section:
https://www.corvetteforum.com/forums...s-1997-2004-2/
Got a technical question about the C5? Use the C5 Technical section:
https://www.corvetteforum.com/forums/c5-tech-1/
General question? There's a C5 General Section:
https://www.corvetteforum.com/forums/c5-general-103/
We encourage new members to take some time to browse around the site and read the Announcements and Stickies as they contain important and frequently asked information.
Thank-you
