Help! Gas Leak...
Hello.
My 2002 Z06 has a gas leak somewhere on the main tank crossover or lines. it starts leaking as soon as i turn the key on and it pressurizes dripping in front of the drivers rear wheel. I assume its filling the bottom plate then running out at the lowest point. I don't have a lift and cant really get under it to see where or what i need to fix it. Is there any one in the Findlay Ohio area with a lift that could help me out.
Thanks Stephen
Thanks Stephen
Hello.
Thanks Stephen
Thanks Stephen
Instead, please find the correct section, based on the generation of the Corvette.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. C5? That's covered under the C5 Corvettes, 1997 - 2004 section:
https://www.corvetteforum.com/forums...s-1997-2004-2/
Got a technical question about the C5? Use the C5 Technical section:
https://www.corvetteforum.com/forums/c5-tech-1/
General question? There's a C5 General Section:
https://www.corvetteforum.com/forums/c5-general-103/
We encourage new members to take some time to browse around the site and read the Announcements and Stickies as they contain important and frequently asked information.
Thank-you
