Help Forum How To | General Corvetteforum Questions | Feedback
Two Factor Authenticaton
Old May 23, 2026 | 02:30 PM
633BR's Avatar
633BR
Default Two Factor Authenticaton
Is the only program allowed to be used here "Authy" or can I use Microsoft Authenticator also?
Old May 23, 2026 | 02:39 PM
J T's Avatar
J T
IB Staff
No, that's not the only program "allowed". A 2FA program that uses time-based one time passwords should work. Not familiar with Microsoft's, but the setup for 2FA makes sure that you have a valid code before it is enabled. Therefore, if the Microsoft app doesn't work while you enable 2FA on CorvetteForum, it won't save. In other words, you should be able to try it without getting locked out.
Old May 23, 2026 | 02:56 PM
633BR's Avatar
633BR
It worked perfectly, The only reason I asked becuase in the directions it specifically calls out Authy
Thanks for the weekend assist!
To Two Factor Authenticaton
