Newby from NC
Old Feb 18, 2007 | 11:51 PM
ssmitty's Avatar
ssmitty
Cruising
Default Newby from NC
Just picked up an '87 C4 about a month ago. It's a good driver with 206K on it. I'm the third owner and the previous owner had already done the engine top end and transmission. So far I've tuned it and with help from here diagnosed an MAF sensor problem. It's running pretty good. I inadverdantly corrected a coolant problem (overheating) by leaving it parked nose up on an incline overnight. The next morning when I started it I got a low coolant light, dumped 2 quarts of water into the coolant bottle and no more overheating. In fact my problem has gone the other direction. I think the prior owner may have taken out the thermostat since it cools down to 140 degrees when I get underway on the road. Oil temp stays around 180 so I don't worry about it too much. I think the low temp may be affecting performance some.
Things are pretty much stock. It's got a K&N air filter and a Magnaflow catback system on it. Sounds good and runs strong. I may get it dyno'ed after I do a few more cosmetic things to it. Hope to have pictures up soon.
Old Feb 19, 2007 | 10:43 AM
TN 2005 C6's Avatar
TN 2005 C6
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
Welcome aboard. Congrats on the Corvette.
Old Feb 19, 2007 | 05:41 PM
Plum Different 73's Avatar
Plum Different 73
You'll get it figured out. Playing with them is one of the things that Vette ownership is all about!
Welcome to the Forum!
, Bob
Old Feb 19, 2007 | 06:32 PM
istsme98's Avatar
istsme98
welcome sounds like a sweet ride
Old Feb 21, 2007 | 01:10 PM
AP's Avatar
AP
Welcome ...
To Newby from NC
