Overheating C4
Old Jun 29, 2007 | 08:28 AM
gking's Avatar
gking
Default Overheating C4
Help! I have a hot momma! My 89 Vette has been a red headed step child with cooling issues for a while now. Bummer because summer driving time is dwindling quickly.
Have replaced the digital cluster (some segments in the temp readout were out), water pump, 2 thermostats, computer/fan coolant sensor and connector near water pump, the sensor feeding digital readout between cylinders 6 & 8, and the radiator cap . Tried burping it last nite, heater on, thermostat was open, coolant flowing, and with the cap off it got up to 260 degrees before I shut it down. Both fans were running ok. There are no signs of water/oil sludge in the valve covers. Am running out of ideas parts to replace!
Any ideas?
Old Jun 29, 2007 | 01:50 PM
ialex2005i's Avatar
ialex2005i
You may want to use the "c4" forum..
Old Jul 6, 2007 | 02:12 PM
QB93Z's Avatar
QB93Z
Welcome to the Corvette Forum.
There is a lot of info about engine temp problems in the C-4 sections. Based on what you have tried so far, I recommend checking your radiator for debris blocking air flow through the fins. MANY C-4's have this problem. None of the other cooling system maintenance will do much good if air can't flow through the radiator.
Good Luck, Jim
Old Jul 10, 2007 | 12:36 PM
DisasterDave's Avatar
DisasterDave
Default C4 Overheating
My '94 get's pretty hot this time of year (Arizona summer doesn't help). I've done alot of what you have done too, I can get up to 230 pretty quick. I just only drive it in the evenings in the summer months. Most likely, I'm gonna need a new radiator because alot of the lower cooling fins are mashed down and destroyed. Have you taken a look at the fins on yours? C4's are lousey at cooling themselves.
Dave
Old Jul 31, 2007 | 03:42 AM
maxmccormick's Avatar
maxmccormick
From what you have done it seems to come back to that radiator. I had an "89 with the same problem. Maybe you can find and borrow a radiator from another vetter and make a swap to see if it helps.
Anyway, the guys over in the C4 section can probably tell you a lot about it.
Good Luck
Old Jul 31, 2007 | 05:45 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I have to agree with the above post. You've done everything else. Try another radiator if you can get your hands on one, but before you do, be sure you've cleaned any deris from the air path. Good luck.
Old Jul 31, 2007 | 09:06 AM
chevy69's Avatar
chevy69
St. Jude Donor '08
Welcome agree you should also post in C4 - lot's of folks don't find their way over to "intro" section. Good luck
Old Aug 6, 2007 | 07:38 AM
KenC6's Avatar
KenC6
Good Luck
My brother had the same problem with his C4. A new radiator solved the problem for him.
To Overheating C4
