C4 California EVAP Test
Old Dec 31, 2008 | 12:02 PM
cesmachines's Avatar
cesmachines
Default C4 California EVAP Test
I own a 1987 C4 with 52,000 miles. A few days ago the car failed the Fuel EVAP test at my local SMOG Test Only station in Southern California. This apparently is a new test instituted last year for cars from 1976 through 1995. They pinch off the hose going to the evaporation canister and then apply 14 psi to the tank and see if the pressure bleeds off. It did. The smog tech said there is a “vapor ” leak between the gas tank and the evaporation canister. The car passed all the other emission control tests.
I suspect it’s one or all of the hoses that connect to the steel tubing coming from the tank and running up to the engine compartment.
Has anyone had this same condition? Is it easy to fix? Where is the best place to take it for repair or can it be done by just purchasing the correct replacement hose and installing it yourself?
Thanks in advance for your help.
B.C.
Old Dec 31, 2008 | 02:54 PM
ugadawg77's Avatar
ugadawg77
Welcome to the forum!
You probably need to repost this in the Tech-Performance section to get a better response, but These are great people & they will help you with this issue. Since I live in Georgia & this is not tested, I wouldn't have a clue. Once again, Welcome!
Old Dec 31, 2008 | 03:00 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Welcome to the forum..
Old Dec 31, 2008 | 05:04 PM
cesmachines
Thanks Guys.
Obviously, I'm new at this.
Old Dec 31, 2008 | 05:36 PM
TN 2005 C6's Avatar
TN 2005 C6
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
Welcome aboard and hopefully you will get the answer you seek in C4 Tech.
Old Dec 31, 2008 | 05:37 PM
guappy's Avatar
guappy
Welcome
Old Dec 31, 2008 | 05:40 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
... and ... Welcome Aboard!
Old Dec 31, 2008 | 06:00 PM
betyelou's Avatar
betyelou
Old Dec 31, 2008 | 08:10 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Welcome to the Corvette Forum!
Old Dec 31, 2008 | 09:24 PM
csexton's Avatar
csexton
Welcome
Chuck
Old Jan 1, 2009 | 02:25 AM
traindude's Avatar
traindude
Welcome aboard!
Old Jan 1, 2009 | 07:04 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome and good luck with the problem!
Old Jan 1, 2009 | 07:43 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Welcome aboard. Enjoy !!!!
Old Jan 1, 2009 | 07:47 AM
dsdrury's Avatar
dsdrury
Good Morning and welcome to the Corvette Forum. Happy New Year, Donn
Old Jan 1, 2009 | 08:55 AM
Roscoe's Avatar
Roscoe
Welcome!
Old Jan 1, 2009 | 10:17 AM
LMH4C5's Avatar
LMH4C5
St. Jude Donor '08-'09-'10
National Champs Gators 4 St. Jude '09
Welcome to the forum B.C.
Old Jan 2, 2009 | 10:23 AM
ALVetteFan's Avatar
ALVetteFan
Welcome to the Forum.
Old Jan 2, 2009 | 01:12 PM
LoneStar26047's Avatar
LoneStar26047
Welcome to the Forum! C4 tech section is what you need.
Old Jan 4, 2009 | 04:05 PM
CENT Z06's Avatar
CENT Z06
Welcome. Very glad you joined!
To C4 California EVAP Test
