New guy from NJ
Thanks again to all.
http://s70.photobucket.com/albums/i1...don/the%20STi/
http://s70.photobucket.com/albums/i1...randon/Racing/
As a driver, I have been on Summit/Jefferson, Pocono (all configs), NJMP (Thunder and Lightning), Englishtown's road course (long and short), lots of hillclimbs, autoX, rallyX, rally sprints... The STi has been to Pocono (east and south), NJMP (Thunder and Lightning), and Englishtown's road course (long and short).
Here is some general specs on the car. Its a java black pearl 2004 STi, just touched 11,000 miles. Was a theft recovery from north jersey... shocking right ; ) Very neutral handling car with a lot of potential. It is fairly mild compared to the time attack beasts that everyone drools over. 350 ft lbs at the wheels on pump with a nice broad torque curve makes it plenty fun. Here are the goodies:
Suspension:
Racecomp tarmac 2’s
Racecomp front camber plates
Group N rear top mounts
Racecomp front sway bar
Racecomp rear sway bar
Whiteline front adjustable end links
Whiteline rear adjustable end links
Perrin rear subframe lock down kit
Energy suspension trialing arm bushings
Cusco front strut tower brace
Perrin adjustable lateral links
"Nissan" front wheel bearings
NEO grease in all wheel bearings
Agency Power pitch stop
Engine:
RS*R ExMag GT2 catback
RS*R Downpipe (wrapped)
IXIZ Air Oil separator
Gimmick MAF hose
APS 70mm CAI
CSS TMIC
Opensource tune by Ray from Turbotektuning: 321whp and 350ft lbs
Brakes:
Hawk blue pads
TiSpeed shims
Power slot rotors
Technafit braided lines
ATE blue fluid
Perrin master cylinder brace
Racecomp carbon fiber brake cooling kit
Performance friction anti knockback springs
Wheels and tires:
Enkei RPF1’s, 17x8 in Gold
Stock silver BBS's
Hoosier Koni challenge spec tires (225 45 17)
Hankook Z214's C51 compound (245 40 17)
Inside outside and other:
Whiteline positive shift motorsports kit
Kartboy shifter bushings
Prodrive shift ****
Redline power pack in everything
Technafit braided clutch line
A/C removed, along with everything else but the dash and front door panels
Perrin wing stiffy
All red tail lights
Aligned and corner balanced at Phoenix performance
Full cage with hd padding
Corbeau FX1 pro seat
G-force 5 point harness w/shoulder pads
IO Port camera mount
Fire bottle
Longacre racing wide rearview
Sparco hood pins (install tbd)
Blind apex in car lap timer
AMB timing transponder
Spring type window net
Headlight armor dark smoke film
