Hello from Tucson Az
Old Aug 2, 2009 | 02:19 PM
corvettejockey's Avatar
corvettejockey
Default Hello from Tucson Az
I have been lurking for awhile now and decided to join. I have read a lot of interesting stuff here. I have a 1981 corvette (my favorite body style). I just recently installed a 2 roll aluminum radiator and the 11 inch dual spal fans from Midamerica. The fans turn on at 95 degrees and off at 75. Well the fans do come on at 95 and stay on because the engine stays hot. I have read the thread about the dual fans and what others are experiencing. What I propose to do is cut the bottom half of my original shroud and re-install it so that it forces the air from the fans up towards the engine to desipitate the heat from the engine.
I have also been told by other corvette enthusiest here in Tucson to get rid of the electric fans because they do not pull enough air and to put the shroud and the original fan back on. I really don't know what temperature I am running at since the temperature guage went hay wire and I had to order another one which has not come in yet. I think that the fans turning on at 95 is already getting to hot. I am thinging of purchasing a sensor that turns the fans on at 85 and stops at 65. I have also been told that the 4 roll radiators are better than the 2 roll radiators because the water moves through the 2 roll radiator so fast that it does not give the water enough time to cool down. Don't know if I truly believe that.
Anyhow, it will be interesting posting with all of you. Take care.
Ron
Old Aug 2, 2009 | 02:34 PM
RicK T's Avatar
RicK T
Welcome to the Forum!!!!!!!! Good luck getting that temp issue sorted out. I'm sure the folks in C3 General will be able to help you. Enjoy the Forums.
Old Aug 2, 2009 | 02:45 PM
csexton's Avatar
csexton
Welcome
Chuck
Old Aug 2, 2009 | 03:00 PM
JungleCat's Avatar
JungleCat
St. Jude Donor '05 thru '26
Welcome on board.
Old Aug 2, 2009 | 03:14 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Welcome to the Corvette Forum!
Old Aug 2, 2009 | 03:28 PM
betyelou's Avatar
betyelou
Welcome to the forum.
Old Aug 2, 2009 | 03:44 PM
jsls0130's Avatar
jsls0130
Old Aug 2, 2009 | 03:57 PM
guappy's Avatar
guappy
Welcome
Old Aug 2, 2009 | 06:43 PM
LMH4C5's Avatar
LMH4C5
St. Jude Donor '08-'09-'10
National Champs Gators 4 St. Jude '09
Welcome aboard Ron
Old Aug 2, 2009 | 10:14 PM
(Lucy)'s Avatar
(Lucy)
Account disabled by request Dec 2015
Old Aug 2, 2009 | 10:19 PM
corvettejockey
Hey all, thanks a lot. I must say that I am in the mechanical designing field just to let you know, so if you have anything that needs to be looked at or considered, like in my case, let me know. Please forgive my run on sentence. Once again, thanks for the welcome.
Old Aug 2, 2009 | 11:02 PM
ccrazor's Avatar
ccrazor
Welcome to the forum..
Old Aug 3, 2009 | 01:47 AM
traindude's Avatar
traindude
Welcome aboard!
Old Aug 3, 2009 | 04:49 AM
RFJohnston's Avatar
RFJohnston
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
Welcome aboard!
Old Aug 3, 2009 | 04:57 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome and good luck with the temp problem!
Old Aug 3, 2009 | 08:11 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Welcome aboard. Enjoy !!!!
Old Aug 3, 2009 | 06:16 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Hello Ron welcome to the Forum Glad to have you here and hope you enjoy it.
Old Aug 3, 2009 | 08:12 PM
TN 2005 C6's Avatar
TN 2005 C6
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
Welcome aboard.
Old Aug 8, 2009 | 08:08 AM
ALVetteFan's Avatar
ALVetteFan
Welcome to the Forum.
To Hello from Tucson Az
