Well after reading all the good stuff in these forums i decided to join. I have a 84 corvette that my wife purchased from a lady she worked with. I was told by my wife it was in pretty good shape, until she purchased it and tried to drive it home. It over heated and cracked the heads. Well i purchased used heads and had a vlave job done . The car finally passed smog so i put it on the road.it did fine until i put it on the freeway got up to about 60mph and start hearing an exhaust leak. Well after looking under the hood i noticed the hoses that attach the air check valve to the tube that goes to the smog pum had burnt completley off on both sides. am i going in the right direction with the AIR CHECK VALVES????
Welcome to the Forum!!!!!!!!!!!! I hope you can straighten out the issues with your C4 and enjoy it. For all of your C4 questions, head over to the C4 General Forum and ask there. The knowledgeable owners there will be able to help you. Enjoy the Forums.
Welcome to the Forum. There are a lot of nice people on the forum, but the people you need to talk to about this are in the C4 Tech/Perf. section. Click on the Forums at the top of the page and go down to C4. When that pull down menu comes up, click on Tech/Performance. Post your question there and I am sure you will receive a number of replies to your question.
