new member
Old Jan 10, 2011 | 02:12 PM
bigalan55's Avatar
bigalan55
Cruising
Default new member
Bought my first corvette last week, a 1999 black hardtop six speed, with 51K on the odometer. Needless to say I'm already having issues with the car, since there was no owners manual included I had to replace the battery in the key fob and it still doesn't work? I have a re-occurring message on the dash that my tire pressure is low, geez what I get myself into???? Al
Old Jan 10, 2011 | 02:26 PM
tom46818's Avatar
tom46818
Welcome to the forum!
Old Jan 10, 2011 | 02:27 PM
TN 2005 C6's Avatar
TN 2005 C6
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
Welcome aboard.
Old Jan 10, 2011 | 03:23 PM
RicK T's Avatar
RicK T
Welcome to the Forum!!!!!!! Congratulations on your C5!! Hope you enjoy the car and the Forums.
First, here's one link to the Owner's Manual online:
http://www.gmpartshouse.com/download...99corvette.pdf
Second, try not to fret too much about the tire pressure thing. While the car is 12 years old and quite possibly the wheel TPMS sensors need to be replaced, the useful life is about 10 years, it may not be that bad. Just go into the C5 General Forum and ask for help. The owners there will steer you straight. Good luck.
http://forums.corvetteforum.com/c5-general-103/
Old Jan 10, 2011 | 04:54 PM
jsls0130's Avatar
jsls0130
Welcome to the Corvette Forum.
Old Jan 10, 2011 | 07:07 PM
traindude's Avatar
traindude
Welcome aboard and Congrats!
Old Jan 10, 2011 | 08:01 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Welcome to the forum..
Old Jan 11, 2011 | 05:26 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome and congrats!
Old Jan 11, 2011 | 09:18 AM
TexBlade's Avatar
TexBlade
Welcome, pull up a keyboard and stay awhile!!!
Old Jan 11, 2011 | 11:59 AM
csexton's Avatar
csexton
Welcome
Chuck
Old Jan 11, 2011 | 04:38 PM
bigalan55's Avatar
bigalan55
Cruising
Thanks for the welcome guys! Funny thing happened- I put air in the tires and the message on the dash went away.... was replaced with "low washer fluid" which was an easy fix.. oil looks like three day old coffee, see it only takes Mobil 1, I was used to changing oil myself on my Toyota Tacoma, but I see this is going to be a challenge. I suppose I can have it done for me, or I could try and find a jack that'll fit under the car, gawd that sounds like a hassle. Going to take some getting used to driving a vehicle that sits so low, seems like my driving habits are the same, (for the most part conservative) but the drivers around me want to race? or challenge the car.... oh well. Alan
Old Jan 11, 2011 | 05:16 PM
RicK T's Avatar
RicK T
If you want to go first class you can get Race Ramps:
http://forums.corvetteforum.com/c6-c...amps-pics.html
Or you can make your own wood ramps. Some examples throughout this thread:
http://forums.corvetteforum.com/c6-c...mp-design.html
Old Jan 11, 2011 | 08:57 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Welcome to the Forum Al and congratulations on your 99 I know the guys in C5 will help with any issues with your car.
Old Jan 12, 2011 | 11:43 AM
Brute's Avatar
0Brute
Former Vendor
Welcome!
A wealth of information on this forum. These members have seen and solved most questions you will have.
Ben B.
Old Jan 12, 2011 | 05:04 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Hi and welcome. The 2 problems are minor and very common to every make and model car. Key FOB batteries last about 3 years and when replaced the FOB must be re-programmed through the DIC.
First try resyncronizing your transmitter.
From the owners manual:
Resynchronizing Your Transmitter
Your RKE system uses a continually changing code for
increased security. Normally, the receiver in your
vehicle will keep track of this changing code. If your
vehicle does not respond to your transmitter, do the
following to determine what’s wrong:
1. Get closer to the vehicle and try pressing a button
again. Your battery may be low. If so, see “Battery
Replacement” in the Index.
2. While standing close to your vehicle, press the
lock and unlock buttons on your transmitter at the
same time and hold for seven seconds. This will
attempt to resynchronize the security code in your
RKE transmitter.
3. When resynchronization is achieved, the horn
will chirp.
If attempts to resynchronize your transmitter to the
vehicle are not successful, you may need to match the
transmitter to the vehicle. See “Matching Transmitter(s)
to Your Vehicle” in the Index.
To match transmitters to your vehicle:
1. Turn the ignition key to ON.
2. Clear any warning messages on the Driver Information
Center (DIC) by pressing the RESET button.
3. Press the OPTIONS button on the DIC several times
until the blank page is displayed, then press and hold
the RESET button for two seconds.
4. When the message FOB TRAINING is displayed,
push the RESET button once. The message HOLD
LK + UNLK 1ST FOB in the DIC will be displayed.
5. Press and hold the lock and unlock buttons on the
first transmitter simultaneously for five seconds.
6. When a transmitter is learned (matched), the DIC
will display FOB LEARNED and then prompt you
to learn the second transmitter.
7. Repeat Steps 5 and 6 for the third transmitter.
8. Remove the key from the ignition.
The programming mode will shut off if any of following
has occurred:
You don’t program any transmitters for two minutes.
You take the key out of the ignition.
You have programmed three transmitters.
Battery Replacement
Under normal use, the battery in your remote keyless
entry transmitter should last about three years.
You can tell the battery is weak if the transmitter won’t
work at the normal range in any location. If you have to
get close to your vehicle before the transmitter works,
it’s probably time to change the battery.
NOTICE:
When replacing the battery, use care not to touch
any of the circuitry. Static from your body
transferred to these surfaces may damage
the transmitter.
Tire Pressure Low:
If you have a re-occurring message on the dash that my tire pressure is low then you must have a slow leak.
From the Corvette Owners Manual:
If a tire pressure message appears on the DIC, stop as soon as you can. Have the tire pressures checked and set to those shown on your
Tire Loading Information Label. See “Extended
Mobility Tires” in the Index.
1999 Corvette Owners Manual: http://www.keystonestatecorvetteclub...99corvette.pdf
2001 Corvette Owners Manual: http://www.c6registry.com/Technical/...01corvette.pdf
Old Jan 12, 2011 | 05:11 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Old Jan 12, 2011 | 06:04 PM
Mike98SilVert
Jacking a C5 or C6:
http://forums.corvetteforum.com/c5-g...-question.html
http://97vette.com/howto/carlift/index.html
To new member
Old Jan 12, 2011 | 07:17 PM
guappy's Avatar
guappy
Old Jan 15, 2011 | 09:09 AM
ALVetteFan's Avatar
ALVetteFan
Welcome to the Forum.
Congratulations on your first Vette.
Old Jan 23, 2011 | 10:51 PM
kawils2's Avatar
kawils2
Default Welcome
Congratulations on your new Corvette & Welcome to the Forum! As you've already seen lots of great information & knowledgeable Vette owners here!
A Corvette is a special machine and like anything exotic it has a few endearing idiosyncrasies. Embrace the fact that you have a unique automobile that will blow the doors off most cars on the roads today.
