My CD changer (12 CDs) mounted in the rear will not power on from the dash. Prior to this I couldn't get the CD holder to eject so I removed from the rear compartment and unplugged the wire harness from the back of the changer. I removed the housing to expose. I was able to get the holder to eject out of the changer. Installed, plugged in the harness and now the on/off doesn't activate the changer. Checked fuser and it's good.
Welcome to the Forum!!!!!!!! Can't help with your question. For most any question about your C5 just head to the C5 General Forum where the members will help you. Also, for your stereo equipment question, you might find faster or better help in the Audio/Electronics Forum. Might want to check the FAQ's in each Forum too. Good luck, I'm sure you'll figure it out soon enough. Enjoy the Forums.
